Webhook URL return links of created posts
Status: Closed · Asked by sepson on · 0 views
Hi I've written a small plugin for WordPress, that offers the ability to create social media posts for Instagram and Facebook.
I'm using the WordPress: New Post Published Webhook URL to transmit the data.
Is there any way to retrieve the links of the created posts from both within the response of the webhook?
At the moment the Webhook response is only:
status: 'success',
message: 'Response Accepted'
}It would be nice to get something like this:
status: 'success',
message: 'Response Accepted',
created_posts: {
instagram: "https://www.instagram.com/p/__POST_ID__/",
facebook: "https://www.facebook.com/__FACEBOOK_PAGE__/posts/__POST_ID__"
}Main reason is, i want to save this in my WordPress database, that this will be easily checked with an click, that all worked fine and the users know, that the post were already published.
You can check it through a webbooks testing site called webhook.site.
You can copy the webhook URL provided by Webhook.site inside your plugin and do the test event inside the application to see if the webhook is being worked inside Webhook.site. This will double-confirm the issue.
Here is a sample video that you can follow to track the webhook issue:
Thank you! This won't help me, because there is no further information in the callback of the webhook. I've done a small workaround with an additonal api call, that will do an official api call to instagram. In the workflow of my facebook post creation, i get an id, that i can reformat to get an valid link. not the best solution, but at least it works ?
Hey @sepson
Thank you for confirming that it works for you. If you require any additional assistance with the API by Pabbly call, please see the video tutorial below.
