Webhook with adding code beore script
Alex1717
Your Task History ID
XxdZa14JBWYCSAljDl0CJQ8bAQUEXgc7ABkHFQMMUioBTwRRB0YPZVgUUHJeGVIzXxYFbw5RBWRaTgcDUgRVJlNJVUdUVwd9VxpVZgBFWmlfAVlxXj8#
Hello. I want to connect nottifications from my IP-telefon serwis to Pabbly via webhook. It need to Add a code in the beginning of the script: <?php if (isset($_GET['zd_echo'])) exit($_GET['zd_echo']); ?>. How to do it on pabbly!? Thanks
ArshilAhmad
Moderator
Hi @Alex1717,
Currently, we don't have a direct integration with the application you are trying to connect with. Please get in touch with your application's support to get this information, as we don't have much information regarding this concern of yours.
ArshilAhmad
Moderator
Please allow me some time to discuss this with my team. We will get back to you with an update soon.
ArshilAhmad
Moderator
Could you please elaborate a bit more on the response you are referring to?
You can have a look at the attached thread below to understand how to configure the trigger if that's what you are looking for.
Alex1717
I must to return:
