Weird problem with code node
Status: Open · Asked by Volker Klärchen on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZjMDYzMTA0M2M1MjZmNTUzYzUxMzIi_pc
Task History ID: IjU3NjcwNTZjMDYzMTA0M2M1MjZmNTUzYzUxMzIi_pc
I have a Pabbly Code node in my workflow. Each time the workflow gets executed it fails at that step with the error:
Failed (502): Internal server error
But when I then re-execute it from the history overview, it works fine without any changes.
This happens every time the workflow is executed.
Hi @Volker,
It appears that you re-executed the action step, due to which we’re unable to determine the exact cause of the error. Please run the workflow again, and if the issue occurs again, let us know without re-executing the task.
Arshil Ahmad
?Rate your support
