What happens with tasks in middle of execution that have a delay, when workflow actions are changed?
Status: Closed · Asked by avielchik on · 0 views
avielchik — Question ·
I have a workflow that i have updated while it was executing many times for incoming webhooks, the issue is they are stuck at a delay after i've updated the workflow and changed the actions. What to do with it?
1. Can i re-execute them with the updated workflow?
2. How can i re-execute them to run at least with the old workflow? (it has worked, just improved it with a router)
3. What to do if i can't do any of those?
Arshita — Reply ·
Hey @avielchik
Yes, you can re-execute the webhooks with the updated workflow.
If you wish to re-execute the webhooks with the old workflow, unfortunately, it may not be possible.
However, you can create a copy of the old workflow and execute the webhooks with that copy.
avielchik — Reply ·
How do i re-execute using the updated workflow?
Arshita — Reply ·
Hey @avielchik
Once you have updated the workflow, go to the Task History and choose the specific task that you wish to re-execute.
Within the workflow, locate and click on the "Re-Execute" button.
This process allows the workflow to run using the most recent changes and configurations you have made.
