What is the default info Pabbly sends to gpt?
Status: Open · Asked by Pabblynaut on · 0 views
I get other results with my custom prompt in Pabbly than in ChatGPT. Is there some background pre-prompting from the Pabbly side?
Hi @Pabblynaut,
We don't apply any pre-prompts from the backend in the ChatGPT action step. Please note that ChatGPT is a generative AI tool, which means it could provide different responses for the same prompt. This may be the reason why you are getting different results for the same prompt.
