whatsapp api to firebase updating fields problem
Status: Closed · Asked by Genio on · 0 views
Genio — Question ·
Hello i have a webhook from whatsapp api, that i want to store in firebase.
I have a collection named responses, and in each document i have 4 fields (Messege, Number, Response, Status)
The only problem is that whatsapp only sends one thing per webhook response. So, if some one sent a message i will get a messege webhook reply
or if someone read my messege, i will get a status webhook reply. Now, if i tried to add the info to my document, Its not possible because firebase update document will tell me there is a missing fields. How can i update only 1 field in the document and not change the rest?
this is the document
lets say i only want to update messege
then the document becomes like this
All the other fields got removed and i only have the new messege!
Thank you
Arshita — Reply ·
Hey @Genio
I request you to refer to the video tutorial provided below for guidance on the WhatsApp API, and try the process from your end.
youtube.com/watch?v=XbHXn8-Q8ow
Additionally, I've noticed that you're inputting data into a field, causing it to become static. In light of this, I kindly request you to map the field from the respective application above and ensure that the field remains dynamic.
