whatsapp callback url is same but not working
Status: Closed · Asked by Parth Nayak on · 0 views
It appears that the workflow is no longer executing. Please follow the steps shown in the video below to create a new connection with your WhatsApp Cloud API account using the webhook.
https://youtu.be/MNxBAsT_zro?si=efOeNqjRpKf6n86q
If the workflow still doesn't get triggered, clone the workflow. The cloned workflow will generate a new webhook URL. Use this new webhook URL in your WhatsApp Cloud API account and check if that resolves the issue.
Arshil Ahmad
🌐 Pabbly.com
call back url working in my whatsapp panel but not working in pabbly. i need not to create permanent token again. it is working with many clients i can not change that token, can we understand issue on gmeet or call
URL gọi lại hoạt động trong bảng điều khiển WhatsApp của tôi
We are not referring to the WhatsApp Cloud API action step, where you need to create a permanent token and establish a new connection.
We are referring to the WhatsApp Cloud API trigger step, where you need to add the Pabbly Connect webhook URL and the Pabbly verification token. We suggest watching the video once so you can better understand what we mean.
https://www.youtube.com/watch?v=MNxBAsT_zro
If you still need a meeting, you can use this link to schedule one with us:
https://calendly.com/d/dtph-2r8-7s5
Arshil Ahmad
🌐 Pabbly.com
Just following up regarding this.
As mentioned earlier, we're referring to the WhatsApp Cloud API Trigger step, not the WhatsApp Cloud API Action step. You don't need to create a permanent token or a new connection for the trigger. Instead, you need to configure the Pabbly Connect Webhook URL and Pabbly Verification Token in the trigger setup. We recommend watching the video once, as it demonstrates the exact configuration we're referring to.
Thanks & Regards,Arshil Ahmad
🌐 Pabbly.com
Just following up one last time regarding this.
Since we haven't heard back, we'll be closing this ticket for now. If you need further assistance, simply send an email to support@pabbly.com.
Arshil Ahmad
🌐 Pabbly.com
