whatsapp flows issue not resolved!
Status: Open · Asked by chandrapal singh on · 0 views
Message:
Hello Pabbly Support Team,
I had earlier posted a thread regarding a WhatsApp Cloud API template issue here:
https://forum.pabbly.com/threads/whatsapp-cloud-api-with-flows-template-error-whatsapp-cloud-api-error-code-131009-–-parameter-value-is-not-valid-when-using-flow-template.28015/
However, the issue has still not been resolved, and now I am unable to view the support team’s response. The forum is showing the following error (screenshot attached):
“Oops! We ran into some problems. You do not have permission to view this page or perform this action.”
? I’m using:
- WhatsApp Cloud API with my number +91 8905161908
- Pabbly Chatflow for replies
- I’ve created a template with View Flow button connected to WhatsApp Flows
❌ When sending the template via Pabbly, I keep getting this error:
pgsql
CopyEdit
(#131009) Parameter value is not valid
OAuthException
Components sub_type invalid at index: 0 and type: …
Please assist me in resolving this issue and grant me access to view the original thread or response so I can take necessary steps.
Thank you in advance ?
Hello @chandu133,
Please refer to this thread - https://forum.pabbly.com/threads/whatsapp-chatflow-message-failed-–-error-100-invalid-parameter-while-sending-template.28016/.
PLease refer to this thread to learn about the template types we currently do not support - https://forum.pabbly.com/threads/pabbly-chatflow-template-synchronization-with-meta.27338/
i have made whatsapp chatflow all data entered in google sheet row successfully, then i want to make auto matched criteria listing from another google sheet with same running flow and for that i have used Lookup Spreadsheet RowV2- Iteretor by pabbly and filter in wgich i want to match three/four criteria that is matching.
can anyone answer that which value to be taken? as flow completed and showing success but there is no data fetched in filter.
