Why do we need a Calendly Pro plan in order to connect with google sheet?
Status: Closed · Asked by NetTrackers Limited on · 0 views
Marketingnettrackers12 — Question ·
When I am trying to connect calendly with a google sheet, then there is an important note in which pabbly mentioned "Make sure you have a Calendly Pro plan in order to use this Integration". This integration is not available for the trial version?
Hey @Marketingnettrackers12
With a Calendly Pro plan, you will have access to more advanced features and integrations that support API use, which is not available in the trial version.
You can visit Calendly's website to learn more about its pricing plans and the features included with each plan.
https://calendly.com/pricing
