Why does my Thrivecart pabbly connect connection keep breaking?
Status: Closed · Asked by mattpx on · 0 views
Hi I have a workflow that I've setup.
Specifcially for Upsells and another one for Order Bumps. I initially set it up - it's working correctly in the live environment - and then, after some time it stops working? The events no longer get logged in the workflow and nothing pushes through to slack?
Why does this keep happening and breaking?
Cheers,
Matt
Hey @mattpx
Can you please reconfigure your trigger event once and then try again?
And if the issue still persists, do let us know.
