"Why does my Webhook Response show correct data, but Code modules receive an empty {} for ?
Status: Open · Asked by TedCA on · 0 views
I have setup a webhook from RocketChat and the Pabbly Webhook appears to be capturing all the data correctly. However, it does not appear to be passing some field data through the workflow pipeline including the results
output hook_text: ERROR: 'text' missing. Full payload: {}
output hook_user_name: Unknown
output _debug raw_data: {}
static fields process correctly, however.
Hello @TedCA ,
Could you please confirm which webhook event you have set up in RocketChat to send the data to Pabbly Connect Additionally, please provide more details about your specific use case.
It would also be helpful if you could share the URL of the workflow you’ve created so that we can thoroughly review it and provide further guidance.
Please be aware that to assist you effectively, we may need to access your Pabbly Connect account. If you’re comfortable with this, kindly include the following statement in your next email:
"You have my permission to log into my Pabbly Connect account, and edit workflow {if required}. Here is the registered email address associated with it:" followed by your email address.
