Why I usually encounter this error with My Hubspot to Google Offline Conversion Work flow?
Your Task History ID
IjU3NmMwNTY1MDYzZTA0M2M1MjY0NTUzYzUxMzY1MTZiNTQzMiI_3D_pc
I have a workflow setup to send offline conversion from Hubspot to Google Ads, its all going good but I suually get this email. Can you help me understand whats the exact issue?
Supreme
@Supreme could you please confirm if it's due to a depreciated API or just a bummer?
It seems that in that instance, the API did not respond, and as a result, Google Ads reported an error. However, if you re-execute the action step, it should work correctly.
