Wishlist member > Airtable : membership level data not captured
Status: Closed · Asked by olimckenna on · 0 views
olimckenna — Question ·
I am sending data from Wishlist member (user added to a level) to Airtable
All data is always correctly sent, apart from the membership level
I have 3 membership levels, e.g. L1, L2, L3
IF I set up the workflow and map the sample user using L1, only L1 memberships are being sent - L2, and L3 return blank
Same if I map the workflow using L2, then users with L1 and L3 get their memberships ignored and no data is being sent
Not sure what to make of this as all other data is mapped and sent without problems
Hey @olimckenna
Could you share your respective workflow with us, so that we can look into it and check the possible arrangement of the level accordingly?
olimckenna — Reply ·
No need, I decided against using Airtable, thanks
