wocommerce create order (with line items) problem
Status: Closed · Asked by Davide Tamanini on · 0 views
Davidetamanini — Question ·
Hi, i have a problem on a workflow on Pabbly connect.
The workflow is a "create woocommerce order (With line items".
So I set it up but have this problem: if I have few then the number of product I had in my test order, the system return me some error becaus data are not responding properly (line items 1 is not properly integer. data type and so on)
I thought that would not search data if line item do not exists.
What can I do?
Do I have to set up a workflow for every possible case? (ie: 1 product, 2 product, 3 product and so on).
Thanks in advice for you help
Hey @Davidetamanini
For your concern, kindly receive the response in advance response by turning off the "Simple Response" and re-capture the webhook response again. Then you can add the Line Itemizer action step to get all the products at once in a comma-separated format.
Please find the attachment and try this at your end.
Davidetamanini — Reply ·
Hi, I have tried it but now ti create always order with 3 product :-(
Hey @Davidetamanini
As we can see from the task history Id of your respected workflow, it is updating all the number of orders as it is coming from the trigger response.
