Woocommerce checkout with Paypal integration using Pabbly Connect
Status: Closed · Asked by chappers on · 0 views
chappers — Question ·
How do i integrate Woocommerce checkout via PayPal to 'Create Customer With Subscription' using Pabbly Connect?
In Pabbly Connect ive chosen the Woocommerce App and added the webhook to Woocommerce webhooks for 'Order Created'. Ive check out via Paypal and the response received in Pabbly Connect was successful. In the Action ive chosen 'Pabbly Subscription' App and the 'Create Customer With Subscription' event.
However, this doesnt work because the Card Number, Expiry and CVV are required fields and this data isn't in the response received.
How do i get this to work???
Hey @chappers
If you don't like to feed those data, you can use the "Create Customer" event where you don't need to fill up the card number, expiry, and CVV.
chappers — Reply ·
Hey @chappers
Yes i know. But whats the point of that?
Whats an alternate way to get payment details from Woocommerce?
Hey @chappers
We looked over your concern and we made some changes as per yours. So we disabled the required fields from the CVV and Card number fields/
And it will only be required if the Payment type is a stripe or Test Gateway. Please check this out and let us know how it works.
