Woocommerce - Elorus Connection Error
Status: Closed · Asked by Benuser on · 0 views
Benuser — Reply ·
I need help with this please
Benuser — Reply ·
Hello, I'm trying to create an API to create contacts on Elorus when a new order is created on Woocommerce but it is showing this error {Authentication credentials were not provided}. What is the issue and any help please.
Treat as Urgent. Thanks
Hey @Benuser
Seems like you have erased the WooCommerce action step in which you are getting the issue.
Hey @Benuser
Kindly refer to the following video lesson on the API by Pabbly action step and then try again.
youtube.com/watch?v=bmf4och_kTk
Also, share the API documentation of the application which you are trying the same.
Benuser — Reply ·
This is the Task history ID
IjU3NjAwNTY0MDYzMzA0MzQ1MjY5NTUzZDUxMzE1MTY0NTQzMCI_3D_pc
Benuser — Reply ·
My client is already complaining, I switched to using api when the direct integration wasn't working. I really need to complete the automation today
Please check your workflow, we have corrected your Elorus API call on API by the Pabbly action step. Kindly check that out.
Benuser — Reply ·
Thank you very much, the response is showing all the lists of the contact instead of creating a new contact. Also, kindly help me create a workflow to create an invoice on Elorus after the contact is created.
That's all, thank you very much for your help
If the API aren't working, this another workflow for the direct integration of Woocommerce to Elorus
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZjMDYzNDA0MzM1MjZkNTUzMDUxMzMi_pc
Kindly help me with both the Elorus to create contact and to create invoice.
You guys are doing well.
Seems like you haven't connected the Elorus action step correctly, so please pass the following API key and Organisation Id correctly.
Benuser — Reply ·
You are trying to create a new connection right? because i've connected everything
Benuser — Reply ·
The connections are correct, just choose one and help me setup the automation to create contacts and invoice
Benuser — Reply ·
Please help me and let's do this together please
We have corrected your API request in the API by Pabbly action step as you were using a few semi-colons and double quotes in the request body.
Though after correcting it seems like the details you have passed were associated with WooCOmmerce only not with Elorus, so kindly pass the Invoice details order details, and Ids available in Elorus. Since you are not passing those correct existing ids from Elorus the Elorus API is showing error messages.
Kindly correct it from your end and then try. If the issue still persists we recommend you contact the Elrous support team.
