WooCommerce Meta Data Extractor Issue
Status: Open · Asked by linkport on · 0 views
linkport — Question ·
Task History ID: IjU3NjUwNTZiMDYzMjA0M2Q1MjZhNTUzNTUxMzc1MTY2NTQzNDBmMzgi_pc
Hi!
We have a workflow (ID: IjU3NjYwNTZlMDYzNDA0M2Q1MjZmNTUzMTUxMzEi_pc) that has been working perfect until September 10 where the "WooCommerce Meta Data Extractor" gets an error (please check attached screenshot).
Can you please check?
Thanks.
Hi @linkport,
Please try deleting the Data Transformer action step and then add it back again. This should fix your issue.
linkport — Reply ·
It worked! Thanks.
Thank you for the update. We’re glad to hear the issue has been resolved. We would greatly appreciate it if you could share quick feedback on the support you received
Thank you for your time.
