woocommerce order is created with multiple products
Status: Closed · Asked by shashank.deshpande on · 0 views
If the woocommerce order is created with multiple products, then there is no solution to map the data and create automation with LMS like teachable. I am trying hard to find the solution on how to map my data and automate my course with teachable if the multiple products are purchased from my woocommerce website. This is very urgent . Please guide me. I watched automation tutorials videos , but there is no such example video I found which explained how to automate when the multiple (products ) courses are purchased.
Please Please Help me !!!
Hey @shashank.deshpande
You can try the iterator action step to take all the orders from your WooCommerce which will take each and every order from your WooCommerce.
For this, you need to receive the response by switching off the simple response and the map the array to the iterator, then you can map the iterators' response to your Google Sheets to feed every order.
Please check out the following tutorial video for a better understanding.
