WooCommerce to Xenforo Integration Help and Questions
Status: Closed · Asked by jasculs on · 0 views
WooCommerce to Xenforo Integration Questions:
1. What if I want to also change the primary usergroup? Is that possible?
2. Am I limited to just the four options? How do I add more options to the XF integration?
3. How do I map a specific product purchase to XF?
Thank you
Hey @jasculs
Our integration team is currently looking into it. Kindly allow us some time to review your concern.
Thanks!!
Hey @jasculs
1. What if I want to also change the primary usergroup? Is that possible?2. Am I limited to just the four options? How do I add more options to the XF integration?
Yes, you can update the primary user group with the user_group_id. Also if you want to add the fields as per your requirement then please let us know, you can check the fields from their API documentation which you required.
API Documentation - https://xenforo.com/community/pages/api-endpoints/#route_post_users_
Hope to hear from you soon!!
