WooCommerce/MailerLite Integration - Specific Product Purchases
Status: Closed · Asked by irishrover on · 0 views
Hi, I can see how you can create a trigger inside Pabbly to integrate with MailerLite once a new order is created. Is there any way you can specify the product because I need to send different emails based on what products people buy.
Thanks, Phil
Use Routers for this -
Thank you soooooo much Fagun
