wordpress post to blogger post
Status: Open · Asked by anixd on · 0 views
anixd — Question ·
I created a workflow for transferring WordPress posts to Blogger posts. Pabbly perfectly creates a new Blogger post when a new WordPress post is created. However, if I update a WordPress post, instead of updating the existing post, it again creates a new post.
anixd — Reply ·
Hello sir, thank you for the quick response. I have set up the update workflow as you suggested, and it's working fine. However, the problem lies with the workflow that creates a new Blogger post when a WordPress post is created. I have re-added that workflow, but it either it creates a Blogger post as an auto-post blank when the 'Post Post Type' is 'post', or it creates a new Blogger post for every update when the 'Post Post Type' is 'revision'. Since I am using the update workflow as provided by you, my only concern is that it should create one blogger post exactly as it is published on WordPress and not as a blank auto-post. Secondly, if there is any update, then it should not create new blog posts in Blogger.
Hey @anixd
Can you please try recapturing the webhook response again from your WordPress account once and then try again?
youtube.com/watch?v=77LNJ77MkjE
anixd — Reply ·
sir i tried this also screenshot of error attached. and rather it updated one of my old blog post that was alredy indexed.
Hey @anixd
Could you attempt again in 24 hours? It seems that the rate limit for Google Bloggers has been surpassed.
anixd — Reply ·
okay will wait
