Workflow connect issue
Status: Closed · Asked by sunny_fst on · 0 views
Hello there , Is there any way to authenticate in workflow while clicking on connect same as like zapier ?
Hey @sunny_fst
You need to authenticate the trigger and action event individually.
Hey @sunny_fstYou need to authenticate the trigger and action event individually.
Hello @Supreme thank you for your reply. I have one more thing to ask you Is there any way to prevent user to access work flow step 2 if user is not authenticated successfully? Like after connecting to app i am requesting API key from user and from there i am trying to authenticate , but the problem is after getting error from our API it is still able to access the step 2.
You can use the Filter action step to process the workflow only when the response gets accordingly.
