Workflow connect issue
sunny_fst
Hey @sunny_fst
You need to authenticate the trigger and action event individually.
Hello @Supreme thank you for your reply. I have one more thing to ask you Is there any way to prevent user to access work flow step 2 if user is not authenticated successfully? Like after connecting to app i am requesting API key from user and from there i am trying to authenticate , but the problem is after getting error from our API it is still able to access the step 2.
You can use the Filter action step to process the workflow only when the response gets accordingly.
