Workflow fields problems still exist even after clearing cache. frustrating.
Status: Closed · Asked by CHRISHOCM on · 0 views
I need help.
I cleared cache daily and hourly trying to use Pabbly but failed - this is for 2 months.
wasting time and unable to execute any task.
Please assist.
Chris
Hey @CHRISHOCM
Can you try removing the action step once and then configure it again?
I tried so many times and on different computers.
Usually the selected fields will be empty and the htm codes will appear.
Please assist.
Is there a technical support personnel to show the errors.
Hey @CHRISHOCM
After investigating your concern it looks like your browser's extension is interfering with your mapping in the workflow.
So, we would recommend you map the data in the incognito mode of your workflow.
