Workflow help
Status: Closed · Asked by salam on · 0 views
Hi guys,
So I ap trying to create and make work my workflow called: Tag welcome call bookers in AC
We are trying to tag every who books this type of call with this specific tag in Active Campaign but it doesnt seem to trigger any ideas?
Hey @salam
The error message from Active Campaign's API suggests that there is already an existing tag, which you are attempting to process in your request, leading to a duplicate entry.
So, if you create a new tag then will process the tag without error. So, can you please elaborate on your use case briefly?
Hey @salamThe error message from Active Campaign's API suggests that there is already an existing tag, which you are attempting to process in your request, leading to a duplicate entry.
Thanks for the reply, we already tried changing the tag but still seems not to work
Can you please share your complete use-case?
It's called: Tag welcome call bookers in AC, we are trying to tag only the clients who have not booked a welcome call with our company, so they receive a reminder to book a call, the process is: Calendly > Filter by Pabbly > Active Campaign
But it doesn't seem to add tags
Hey @salam
Regarding your concern we suggest utilizing the "ActiveCampaign: Create or Update Contact" action step. This will not only add the desired tag but also create the contact if it does not already exist.
