workflow is not triggering
Status: Closed · Asked by Danny Skulls on · 0 views
danny aculla — Question ·
hello,
I built a workflow named
[TABLE]
[TR]
[TD]
google drive to google sheet quotes
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD]
[/TD]
[/TR]
[/TABLE]
which is not working properly, trigger is set when a file is added to google drive folder and once assets have been added to the trigger file in google drive nothing is happening.
please help
Arshita — Reply ·
Hey @danny aculla
I request you execute this workflow in the incognito mode of your browser.
Additionally, I would advise you to make a completely new connection with Google Drive and try executing the workflow again.
This will help to ensure that any potential conflicts or errors arising from prior connections are avoided and that the workflow can be executed smoothly and effectively.
