workflow is not triggering
Status: Open · Asked by DM PURE EV on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY4MDYzNzA0MzE1MjZkNTUzMzUxM2Ei_pc
flow is not triggering even after new row added to sql tableHi @PURE EV,
Your workflow is being triggered when new data is added to your MySQL table, but in some instances, it is not being added to Google Sheets.
Instead of using Delay For, please use the Delay After Queue action step as step 2 of your workflow. This will fix the errors you are encountering.
Arshil Ahmad
?Rate your support
