workflow is not triggering
PURE EV
Your Workflow URL
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY4MDYzNzA0MzE1MjZkNTUzMzUxM2Ei_pc
Consent to Access & Modify
I authorize Pabbly Support to log in to my account and make changes to the specified workflow for troubleshooting.
flow is not triggering even after new row added to sql table
ArshilAhmad
Hi @PURE EV,
Your workflow is being triggered when new data is added to your MySQL table, but in some instances, it is not being added to Google Sheets.
Instead of using Delay For, please use the Delay After Queue action step as step 2 of your workflow. This will fix the errors you are encountering.
Arshil Ahmad
🌐 Pabbly.com
👉Rate your support
