Workflow not starting by itself
Status: Closed · Asked by Dental Center on · 0 views
Dental Center — Question ·
Hi I set up a workflow like this: Trigger (Facebook Lead Ads - New lead) ---> API (That catches the phone number and send a whatsapp message)
When i click in "save and send a test request" it works fine. But if someone register in the form the workflow doesn't activate by itself, i have to go there and click in "save and send a test request" everytime. My plan is free, I don't know if this is a problem. Can someone help? I will send the workflow link here: https://connect.pabbly.com/workflow/share/C0NXZVYNA2JQGQldUTxQM1hLCj1XC1ZsXExUXQdiXRs#
Fagun Shah — Reply ·
1. Did you turn on the workflow after setting it up
2. FB lead Ads is a polling base integration, so it can take upto 5-10 min to actually get your lead data after form submission.
3. You can do testing using this tool - https://developers.facebook.com/tools/lead-ads-testing (by submitting dummy leads in the form and checking if they enter the workflow in 10 min or not)
Fagun Shah
- Automation Freelancer
Pabbly — Reply ·
Please enable your workflow so that it can work in live mode-
