workflow not triggering
Status: Closed · Asked by realestatebroker on · 0 views
Arshita — Reply ·
Hey @realestatebroker
As I can check from your workflow, it appears that the data is triggering. However, you are facing two specific issues: one with the Google Sheets and another with the ChatGPT server.
Regarding the Google Sheet issue, we found that a required field was missing, and we have made the necessary changes in your workflow. I kindly request you to check now from your end by capturing the data once again.
For the ChatGPT server issue, I recommend reconnecting with the ChatGPT application and try again. This should help resolve the problem.
Please let me know if you are still facing the same issue.
