Workflow step not executed.
Status: Closed · Asked by Carlos Melo on · 0 views
A step of a workflow did not run and I can't find the reason.
I received an email stating that the reason was as follows:
"error > code": 400,
"error > message": "Invalid JSON payload received. Unknown name \"\": Root element must be a message.",
"error > status": "INVALID_ARGUMENT",
"error > details > 0 > @type": "type.googleapis.com/google.rpc.BadRequest",
"error > details > 0 > fieldViolations > 0 > description": "Invalid JSON payload received. Unknown name \"\": Root element must be a message."
Task History ID: IjU3NjAwNTZmMDYzNDA0MzQ1MjY0NTUzNTUxMzA1MTY0NTQzOSI_3D_pc
So please, anyone could tell me where is the problem ?
Hey @Carlos Melo
We have checked the scenario and found that you are pressing Enter key after the first line and it is causing the issue. Kindly make sure to not to press the enter key and enter all the text.
Please let me know if you have any questions or comments.
Kunal
Ok, thank you very much, Kunal.
