xero invoice not saving
Status: Closed · Asked by katalystjay on · 0 views
katalystjay — Question ·
Thank you for reinstating the Xero integration
I am finding that I cannot save an Invoice, though i can save and invoice with line items. Is this replicated on your end?
Hey @katalystjay
We are planning to deprecate the "Xero: Create an Invoice" action event from their integration on the platform but you can use its upgraded version as "Xero: Create Invoice (with Line Items)".
Kindly try this at your end and let us know if that helps you out.
