Xero
Status: Closed · Asked by Lachlan Macdonald on · 0 views
I want to start with * when a invoice is raised in XERO.....i cant seem to find any connection that starts with xero is this the case or what?
Xero integration does not have any triggers, that is why you are not able to find it in first step of the workflow(trigger).
https://www.pabbly.com/connect/integrations/xero/
But you can request them to update the existing Xero integration here - https://pabbly.hellonext.co/b/Update-Existing-Application
