Zoho Multi-Select Lookup Field not populating
Status: Closed · Asked by trofimartya on · 0 views
Hey all!
Problem is as following:
Im trying to pass data to Zoho Multi-Select Lookup custom field but always getting this error: http://joxi.net/82Q3zz9t41aPbr
Im passing id of another custom module that has been created in previous step: http://joxi.net/l2Z8DD9iV8YD4r
I wonder if its limitation of Zoho or something wrong in Pabbly. Seems like data should be passed in json format, and I've already tried this. But in the end im getting same error: Expected Data Type - jsonarray.
Please help.
Hey @trofimartya
Currently, a lookup field in Pabbly Connet is not supported in the Zoho integration.
Hey @trofimartyaCurrently, a lookup field in Pabbly Connet is not supported in the Zoho integratio
Do you have another workaround for this?
Unfortunately, there is no other workaround available.
