Zoom connection problem
Status: Closed · Asked by milansingh2789 on · 0 views
Hi
Previously the zoom integration was working perfectly but from today 8 August, it is showing an invalid access token. I have added the zoom account many times but the error comes after some minutes. Kindly look into this.
Hey @milansingh2789
If you have generated a new connection for your Zoom action step then you should always use the latest one.
Kindly try again and let us know if that works for you.
