  • Important: Any reported problems and issues with your integration will be reported to you and we will encourage the app developers help to resolve those integration issues.
Multi Step in Post Webhook
In the case of a Post Webhook, we encounter a scenario in which multiple steps are required during setup and, occasionally, in automation. Some of these steps are applicable in both contexts.
To manage these situations, we have implemented multi-step processes that will execute under the following conditions:
  1. Each Execution (Default) -
    The multi-step process will run consistently with every action/trigger.
  2. Post Webhook Setup -
    The multi-step process will execute only at the time of post-webhook setup.
  3. Post Webhook Event Trigger
    The multi-step process will only execute when the webhook is triggered in automation.
Here is the Post Webhook trigger's example:
