Auto Pabbly Connect Running Workflow
ansh010
Your Task History ID
IjU3NjEwNTY0MDYzMjA0Mzc1MjZhNTUzMjUxMzM1MTY0NTQzMiI_3D_pc
Hello Team,
I have a Pabbly Connect Workflow linked with Google Sheets, But now it is automatically running like many times and consumed my task so much and started populating my telegram group with old entries that are been not even triggered from my side in google sheets. Please Help because still it is sending many messages in my telegram groups.
Hey @ansh010
Kindly check it through a webbooks testing site called webhook.site.
You can copy the webhook URL provided by Webhook.site inside your application and do the test event inside the application to see if the webhook is being worked inside Webhook.site. This will double-confirm the issue.
Here is a sample video that you can follow to track the webhook issue:
Upon reviewing your workflow, it's evident that you are utilizing "Webhook by Pabbly," a webhook trigger known for its webhook-type trigger event, specifically designed to receive data sent by the triggering application without any modifications to the data's structure or content. We recommend you initially verify the incoming data in Webhook.site, as this will help identify whether you are receiving the same data multiple times from the triggering application which is coming in your Google Sheets from third party application.
