Automation Go High Level
Openfy
HI! I'm creating an automation with Pabbly to create an automatic sub-account with Go High Level but when I get to the end the system gives me an error message. Why? My plan with Go High Level is the 297...
ArshilAhmad
Moderator
Hi @Openfy,
Please verify from your Agency account if it has all the permissions to create a sub-account. For those with Agency access, go to Agency View >> Settings >> Team. Locate the team member you'd like to set user permissions of
  1. Click the Action button (Pencil icon) next to the user's name
  2. Choose Roles & Permissions
  3. Click on the corresponding checkboxes and sliders for the permissions you want to set for that user.
  4. Click Save after
Note: To get to these settings, you need to be either an Agency Admin or Account Admin for a particular Sub-account.
Fagun Shah
I am facing the exact same issue as well, it works in v1 but doesn't work in v2. I have tried to contact ghl support but no replies yet.
Let me know if you find a solution from GHL team.
Hey @Openfy
Can you please tell us what subscription type you are using for LeadConnector?
Openfy
I tried V1 of Lead Connector but, once connected, it asks me to enter the API Key which in the Freelance plan (from $297) doesn't show it to you!
Openfy
So it's not possible to automate the creation of sub accounts with Pubbly and Go High Level's $297 plan??
Hi @Openfy,
  4. Click Save after
ArshilAhmad
Moderator
After consulting with the LeadConnector team, we learned that the 'Create Location' feature is exclusive to agencies on the $497 plan. Customers on the $297 plan may encounter this error(The Company doesn't have access to this feature).
We suggest you get in touch with GHL's support team to gain a better understanding of this issue.
