BOTSTAR Integration error : Invalid access token, please help.
abuhabib
Cannot connect to Botstar. Just copied access token info directly from Boststar api but seems to be Invalid access token.
Pabbly
Administrator
Sorry for the inconvenience. Please allow some time to check on this.
We will get back to you in a while.
Pabbly
Administrator
Please go through following step to get the API key from your Botstar account -
Step1
Step2
abuhabib
already did that, and it seem working and connected. But when i try to use send message features. Its show an invalid token.
abuhabib
And 1 more thing, if i use send message features, how do pably recognize which bot will send message to boststar users. There is no option to select bot, just like this module
Hey @abuhabib
We currently looking into your concern, we will get back to you with an update shortly.
Please check your workflow now. It should work properly now. Regarding your other question where you asked how Pabbly recognize which bot will send message to Boststar users. Well, the user ID which you're mapping can only be got from a Specific Bot through which you wish to send messages.
Here's the way to get User ID- Go to the Specific Bot > Reports & Insights > Select the User > Information > ID
Further you click on refresh field button to view all your bots -
