  • Please note that the team will not be available on 7th September 2024, due to a public holiday in India.
    During this period, support assistance may experience some delays.
can create some temporarily variable inside Pabbly Connect workflow?
tisaigon
i use Podio connect with Google sheet/Facebook.
but i don't want direct from Podio to Google sheet/Facebook.
Can i add some variables inside workflow.
Example:
variable x = field 1 of item A in Podio
variable y = field 2 of item B in Podio
then I will use some changes to the variable x, y
then I will make some changes to these variables : new_x, new_y
I will add these converted variables new_x, new_y to Google sheet/Facebook eventually
How can i define variable x, y in Pabbly Connect?
Thank you
ArshilAhmad
Moderator
Hey @tisaigon,
To define the variables x and y, you just need to map both fields from the previous steps.
Let's suppose we fetch details of two different items using Podio: Get Item Details.
Item A
Item B
After that, all you need to do is map the fields you want to change. For example, let's say we want to change the title of Item 1. In this case, we would map the Title field from Item 1 in our Action Step to make the necessary changes. In a similar manner, we can map the field from Item 2 and change it.
