Can pabbly differentiate between charge captured and charge authorization?
Status: Closed · Asked by nick.roch@petrampvc.ca on · 0 views
I have an ecommerce website that uses stripe to collect credit card payments. The website collects a payment authorization which is later manually captured after reviewing the order. I would like to set up a pabbly workflow to trigger only when a charge is captured but ignore the authorization charges.
The most suitable stripe trigger seems to be "new charge" however that trigger is looking for event "charge.succeeded" this event occurs whenever a new charge is made, including authorizations. However it does not seem to trigger when a charge is captured (perhaps as its not a new charge, instead updating an existing charge created by the authorization?) The event i think i need to listen for is "charge.captured".
Is there a way to listen for captured charges?
Is there a better trigger to use?
Can i use the "new charge" trigger but instead select the "charge.captured" stripe event instead of "charge.succeeded"?
Thank you!
Hi @Petram PVC,
You can use Webhook by Pabbly as your trigger step, and in Stripe, select the webhook event that best suits your use case.
