Character Limit Problem in Pabbly Connect Text Transformer Function
Status: Open · Asked by skoolio on · 0 views
I am getting google doc of class transcription and I am removing unwanted character using text tranformers to save tokens in chatgpt
Could you please help how to deal with character length
Getting this error:
Field(s) text, pattern character length exceeded the allowed max value. Learn more: https://forum.pabbly.com/threads/maximum-character-length.10600/
Hi @skoolio,
Hi @skoolio,
Our team has made some changes to the limits. Could you please try performing the action again and let us know if everything works fine now
Still facing the same issue -
Please allow us some time. We will get back to you shortly.
Task History ID - IjU3NjUwNTZmMDYzMzA0MzY1MjY4NTUzMzUxMzI1MTZiNTQzNTBmMzUi_pc
Based on your Task History, we can see that you are attempting to extract a pattern from a string containing more than 250,000 characters. Please note that the maximum allowed character limit in Pabbly Connect is 250,000 characters. Your document appears to exceed that limit, which is why you are encountering the error. Unfortunately, there is no workaround for this.
Is there any other method by which we can do this?
I’m afraid there is no other method or workaround for the issue you are encountering.
