Combine products and plans with ease
Daily
Is there a way to combine products or move one so I can add a product to a new plan? I would love to be able to switch stuff around without having to recreate a product. Maybe there is another workaround?
V
Vipin Mishra
Hello @Daily,
We would like to inform you that currently Pabbly Subscription Billing (PSB) does not support this feature for combining different products or Plans but yes we provide our users with the option of Clone through which you can easily copy any plan and make the similar plan like the earlier one with some slide modifications as per your business requirements. So you make different plans with some changes into the same product range.
If you need further support please reach out to us.
Regards,
Vipin Mishra
