Connecting Wix to Pabbly Connect
Ask Omar
Hi all,
I am trying to connect my Wix account to Pabbly so that I can create a workflow.
However, I have had trouble with this stage after following instructions.
I have created an App in Wix and generated the API Key, but after inserting these info in Pabbly, I get a failed outcome.
Anyone experienced this and have the solution, please?
Thanks!
Subin
Hey @Ask Omar !
Kindly provide us with the screenshot of the error you have received at your end?
Also, share the workflow URL in which the issue has arised?
Furthermore, here is a video tutorial for your reference on how to connect with Wix-
Hope, to hear from you soon.
