Connection Guide: Supabase Setup
Connection Guide: Supabase Setup​
Complete this setup guide to enable CRUD operations (Create, Read, Update, Delete) in Supabase through Pabbly Connect. Follow each step carefully to ensure proper configuration.
1. Create Your Supabase Account​
  • Visit supabase.com
  • Click "Start your project" or "Sign Up"
  • Create an account using your email, GitHub, or other available options
  • Verify your email address if required
2. Create a New Project​
  • After logging in, click "New Project"
  • Fill in the required details:
    • Project Name: Choose a name for your project
    • Database Password: Create a strong password (save this securely)
    • Region: Select the region closest to your users
  • Click "Create new project"
  • Wait for the project to finish setting up (this may take 1–2 minutes)
3. Retrieve Your Project Credentials​
You'll need these credentials to connect Pabbly Connect with Supabase.
Finding Your Project URL:​
  • In your Supabase dashboard, go to Project Settings (gear icon in the left sidebar)
  • Navigate to API section
  • Under Project URL, copy the URL
  • Example: https://your-project-id.supabase.co
Finding Your API Key (anon/public):​
  • On the same API page
  • Scroll to Project API keys
  • Copy the "Publishable key"
  • Example: sb_publishable_vYk*****tOxJg_6gg2cHP4
Important: Save both the Project URL and API Key – you'll need them to configure Pabbly Connect.
4. Create Test Schema and Table​
Now you'll set up a test environment with a sample table to verify everything works.
4.1: Access SQL Editor​
  • In your Supabase dashboard, click SQL Editor in the left sidebar
  • Click "New query"
4.2: Run the Setup SQL​
Copy and paste the following SQL code into the editor, then click "Run":
SQL:
CREATE SCHEMA IF NOT EXISTS test_schema;
GRANT USAGE ON SCHEMA test_schema
    TO anon, authenticated, service_role;
CREATE TABLE IF NOT EXISTS test_schema.pabbly_users (
    id BIGINT GENERATED BY DEFAULT AS IDENTITY NOT NULL,
    created_at TIMESTAMPTZ NOT NULL DEFAULT now(),
    first_name TEXT NULL,
    last_name TEXT NULL,
    email TEXT NULL,
    phone TEXT NULL,
    CONSTRAINT users_pkey PRIMARY KEY (id)
) TABLESPACE pg_default;
ALTER TABLE test_schema.pabbly_users
    ENABLE ROW LEVEL SECURITY;
CREATE POLICY "full access pabbly_users"
    ON test_schema.pabbly_users
    FOR ALL
    USING (true)
    WITH CHECK (true);
GRANT SELECT, INSERT, UPDATE, DELETE
⚠️ Important Note: This configuration grants full access to the anon role, which is intended for testing purposes only. In production, you should implement more restrictive security policies.
5. Configure GraphQL API Settings​
To perform GraphQL queries on your custom schema, you need to add it to the search path.
5.1: Navigate to API Settings
Dashboard → Project Settings → Data API → API Settings → Extra search path
  • Go to Project Settings (gear icon in left sidebar)
  • Click on Data API in the settings menu
  • Scroll down to API Settings section
5.2: Add Schema to Search Path​
  • Find the "Extra search path" field under Data API Settings
  • Add test_schema to the extra search path
  • Click "Save" to apply changes
This step ensures your GraphQL queries can access tables in the test_schema schema.
6. Create Helper Functions (RPC)​
These functions will help Pabbly Connect discover your schemas, tables, and columns dynamically.
6.1: Access SQL Editor​
  • Click SQL Editor in the left sidebar
  • Click "New query"
6.2: Create the Functions​
Copy and paste the following SQL code and click "Run":
SQL:
CREATE OR REPLACE FUNCTION public.list_user_schemas()
RETURNS TABLE(schema_name text)
LANGUAGE sql STABLE SECURITY INVOKER
AS $$
    SELECT schema_name
    FROM information_schema.schemata
    WHERE schema_owner NOT IN ('supabase_admin', 'pgbouncer')
      AND schema_name <> 'extensions'
    ORDER BY schema_name;
CREATE OR REPLACE FUNCTION public.list_tables_for_schema(p_schema text)
RETURNS TABLE(table_name text)
AS $$
    SELECT table_name
    FROM information_schema.tables
    WHERE table_schema = p_schema
      AND table_type = 'BASE TABLE'
    ORDER BY table_name;
CREATE OR REPLACE FUNCTION public.list_columns_for_table(
    p_schema text,
    p_table text,
    p_mode text DEFAULT 'select'
RETURNS TABLE (
    column_name text,
    data_type text,
    is_primary_key boolean
AS $$
    SELECT
        c.column_name,
        c.data_type,
        CASE WHEN tc.constraint_type = 'PRIMARY KEY' THEN true ELSE false END AS is_primary_key
    FROM information_schema.columns c
    LEFT JOIN information_schema.key_column_usage kcu
        ON c.table_name = kcu.table_name
        AND c.column_name = kcu.column_name
        AND c.table_schema = kcu.table_schema
    LEFT JOIN information_schema.table_constraints tc
        ON tc.constraint_name = kcu.constraint_name
        AND tc.table_schema = kcu.table_schema
        AND tc.constraint_type = 'PRIMARY KEY'
    WHERE c.table_schema = p_schema
      AND c.table_name = p_table
      AND (
            p_mode <> 'update'
            OR c.column_name NOT IN ('id', 'created_at')
    ORDER BY c.ordinal_position;
These functions are stored in the public schema for convenience and will be called by Pabbly Connect to discover your database structure.
7. Connect to Pabbly Connect​
Now you're ready to integrate Supabase with Pabbly Connect!
  • Open your Pabbly Connect workflow
  • Add a Supabase action step
  • When prompted, enter:
    • Project URL: The URL you copied in Step 3
    • API Key: The Publishable key you copied in Step 3
  • Save your connection
✅ Setup Complete!​
Your Supabase database is now configured and ready to perform CRUD operations through Pabbly Connect. You can:
  • Create new records in test_schema.pabbly_users
  • Read existing records
  • Update record information
  • Delete records
Test Your Setup​
Try creating a test record in the pabbly_users table through Pabbly Connect to verify everything is working correctly.
⚠️ Important Security Notes​
This setup uses permissive security policies for testing. Before moving to production:
  • Review and restrict Row Level Security (RLS) policies
  • Limit the anon role permissions to only necessary operations
  • Implement proper authentication and authorization
  • Never expose sensitive data through the anon role in production environments
For production environments, consult the Supabase Security Documentation to implement proper security policies.
Need Help?​
If you encounter any issues during setup:
  • Check the Supabase Documentation
  • Review your SQL Editor for any error messages
  • Verify that all SQL commands executed successfully
  • Ensure your API credentials are correctly copied
  • Error like this :
  • Explanation & Solution:
    This occurs when your table’s Row-Level Security (RLS) policies do not allow the action you are trying to perform (e.g., INSERT). To fix this
    Refer to the official Supabase documentation for guidance: Row-Level Security (RLS) in Supabase.
