ERROR zoho books
dsgadmin
Trying to create a contact with web portal enabled and I get this error:
I have the same issue. What is the solution?
My workflow url
As we can see from your respective workflow, we can see that your Zoho Books action step is working fine.
Hey @stellar.tone
Please consider configuring your Zoho Books account with the client portal settings, or you can verify this with the Zoho Books support team.
Hey @stellar.tone
Let me restate this question:
When using pabbly to "create a new contact",
Is pabbly able to automatically configure the customer portal and turn the customer portal feature on for the NEW contact that was just created using pabbly?
Customer portals is currently on in my zoho books.
As observed in your Zoho Books: Create Contact action step, you are required to set the following field to False.
After configuring it to False, the action step is functioning correctly.
Disregard the instructions for configuring Customer portals in your Zoho Books, as mentioned earlier. Instead, please enter 'False' in the following field and then attempt the task once more.
