Paula
The 'Get Seller Taxonomy nodes' method of the Etsy integration keeps loading when I select 'Simple response'. I think the issue is that the response is too large. When I deselect the simple response, I can see the JSON is cut off.
Also, for the 'Create Draft Listing' method of the Etsy application, the value 2020_2023 of the property 'When made' is mapped to '2020-2024', since the option '2020-2023' is no longer available.
