Facebook Comment Automation according to specific words
Hey @MahmudulAlam
I want to automate Facebook Comments if someone comments using "price" for a specific post. Possible?
You can check out our tutorial video, for a similar use case. Kindly try this at your end and let us know if you get stuck at any step or need any further assistacne.
Hey @MahmudulAlam
You can use the "Filter" action step with the "Contains " filter type which will check for the word price if that word presents in the message content then only it will process the automation accordingly.
I hope this will help you out.
