Field match issue! Educate me please
PabblyMember4
Hey @EricHowell
We can see that in Data In we are correctly sending the data in the fields. However we are not sure about the Data Out field as it is not giving any information.
Meanwhile could you please remove the extra spaces in the {{ contact.seller_1_name}} and then try to pass the values in the document and let me know if it helps.
Kunal
Hey @EricHowell
Kunal
Hey @EricHowell
Kunal
Here is one of the workflows https://connect.pabbly.com/workflow...CaANfADwBFVZSVQMBcgMNARQEGwdaVmUARVYJASsPbQ##
A
Arshita
Hey @EricHowell
I would like to request you to manually input the text instead of simply copying and pasting it into the document. Once you have manually input the text, please reconnect and try to pass the values in the document as needed.
If you experience any issues or errors while passing the values, please let me know and I will be happy to assist you further.
