Field(s) code character length exceeded the allowed max value.
Status: Closed · Asked by RajAnwar on · 0 views
RajAnwar — Question ·
I have used API Pabbly action and got lot of JSON Data. I want specific data from that json data but i am unable to use any actions to get the required data because every action where i am trying to get required data is showing the same error as "Field(s) code character length exceeded the allowed max value. Learn more: https://forum.pabbly.com/threads/maximum-character-length.10600/".
We can use actions like
1)Data Transformer (Pabbly) in that action is Line Itemazor
2)Code
3)Array action
All these actions resulting error as "Field(s) code character length exceeded the allowed max value."
Please Resolve this issue
Hey @RajAnwar
Please provide more details about your issue with Pabbly's API, including the specific API call you executed. Additionally, share the workflow URL so that we can examine it further.
RajAnwar — Reply ·
When used API Pabbly, received alot of data as response. Later from that huge data specific data is not able to bring out.
We will require you to check your workflow in terms to check the issue, so please share the workflow URL from your Pabbly Connect account.
